Problem with the video card, I think, in Ubuntu
marcob9999
Hello everyone.
Today I opened REW (after a long time) and the windows are completely black!!!
Only in the main window, if I resize it, I can see something, but as soon as I click something, the windows go back to black.
When I hover over the various buttons with the mouse, they appear, then disappear as soon as I move the mouse.
I have tried installing the latest beta version, but nothing changed.
Then I deleted REW and installed version V5.31.3 and still nothing changed.
It seems like a problem with the video card (probably caused by an update), but these things are beyond my capabilities :justdontknow:
The operating system I'm using is UBUNTU 24.04.3.LTS.
Does anyone have any suggestions???
Thanks a lot!!!
Marco
Maybe your system switched from X11 to Wayland? What does
Code:
echo "$XDG_SESSION_TYPE"
say ?
YES!
The answer to your command is: wayland
:hissyfit: updates :rolleyesno: ...
If this is the cause (as you think), what can I do :dontknow: ?
Many thanks for your answer!!!
Marco
Switch your desktop to X11 and check if it helps. Just google out the method (it should be at login screen).
