Johren Higgins
- Feb 12, 2019
- Messages
- 2
Hi, I finished the measurements for my home studio and only one appears to function properly. 1 of 7 contains the soundcard calibration file and mic meter data. As a result i'm unable to generate a waterfall for the 6 missing the data. In addition, I can only remove the default 1/48 smoothing from with one with the data. I deselected 'Allow 96 PPO log spacing', and pressed apply to window on the IR windows page. However this only works for the measurement with the data, for the others the IR windows page is blurred out. Is it possible to apply the data to the measurements or will I have to do them again? I suspect something went wrong with my ASIO drivers during the process, although i'm confused why this didn't affect the 3rd measurement lool. I've attached an image showing what I mean. I'm using beta 5.20
Excuse the bad explanation, i'm still new to this stuff.
Cheers
Cheers
