Problem with Java...
marcob9999
Hello everyone.
I have installed REW (REW_linux_5_20_RC12.sh) on Linux 21.04 (Hirsute Hippo) , and I have a problem when I try to create a waterfall.
It gives me this error:
REW V5.20 running JRE 1.8.0_292 64-bit on linux 5.11.0-25-generic, it, IT, UTF-8 at 96 DPI
Message:
java.lang.InternalError: not implemented yet
Stack Trace:
not implemented yet
sun.java2d.xr.XRSurfaceData.getRaster(XRSurfaceData.java:72)
sun.java2d.loops.Blit$AnyBlit.Blit(Blit.java:163)
sun.java2d.pipe.DrawImage.blitSurfaceData(DrawImage.java:959)
sun.java2d.pipe.DrawImage.renderImageCopy(DrawImage.java:577)
sun.java2d.pipe.DrawImage.copyImage(DrawImage.java:67)
sun.java2d.pipe.DrawImage.copyImage(DrawImage.java:1014)
sun.java2d.pipe.ValidatePipe.copyImage(ValidatePipe.java:186)
sun.java2d.SunGraphics2D.drawImage(SunGraphics2D.java:3320)
sun.java2d.SunGraphics2D.drawImage(SunGraphics2D.java:3298)
roomeqwizard.bF.A(y:559)
roomeqwizard.bF.A(y:2021)
roomeqwizard.CI.A(y:1681)
roomeqwizard.CI.A(y:2605)
roomeqwizard.CI.A(y:1556)
roomeqwizard.CI.paintComponent(y:3195)
javax.swing.JComponent.paint(JComponent.java:1056)
javax.swing.JComponent.paintChildren(JComponent.java:889)
javax.swing.JComponent.paint(JComponent.java:1065)
javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
javax.swing.JLayer.paint(JLayer.java:433)
javax.swing.plaf.LayerUI.paint(LayerUI.java:79)
javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)
javax.swing.JComponent.paintComponent(JComponent.java:780)
javax.swing.JLayer.paint(JLayer.java:428)
roomeqwizard.NB.paint(y:2131)
javax.swing.JComponent.paintToOffscreen(JComponent.java:5210)
javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:290)
javax.swing.RepaintManager.paint(RepaintManager.java:1272)
javax.swing.JComponent._paintImmediately(JComponent.java:5158)
javax.swing.JComponent.paintImmediately(JComponent.java:4969)
javax.swing.JLayer.paintImmediately(JLayer.java:415)
javax.swing.plaf.LayerUI.paintImmediately(LayerUI.java:717)
javax.swing.JLayer.paintImmediately(JLayer.java:410)
javax.swing.JComponent.paintImmediately(JComponent.java:4950)
javax.swing.RepaintManager$4.run(RepaintManager.java:831)
javax.swing.RepaintManager$4.run(RepaintManager.java:814)
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
I've already tried re-installing java8 (sudo apt-get install openjdk-8-jre), and re-installing REW, but nothing changes ...
Can someone help me?
Thanks so much!!!
Best Regards.
Marco
Select the option Use OpenGL in the installer:
43658
