Preamp for Earthworks M23R
charbug
I need a to buy a descent preamp for an Earthworks M23R. I was using a RME UC interface that had an internal Mic preamp but this unit does not play well with Jriver, and now I am going to get Lynx Hilo for an interface and i find myself needing a descent Preamp to use with it when I run REW. I hope to find a good budget one and I would appreciate some recommendations,
Thanks!
Wayne A. Pflughaupt
Corpus Christi, TX
Roku Express
Canton Karat 920
Canton Karat 920
Canton Plus D
Hsu ULS-15 MKII
Stock Yamaha Remote
For REW, the simpler the interface, the better. Here’s a great post on the topic from Home Theater Shack.
andreicnt
I would go for this type of preamps. Those are very colored preamps you need the most transparent one, Fireface UC is a much better option, you don’t need another pre.
When it comes to drivers apart from the MacOS USB class drives I do not know more stable driver than RME’s.
Andrew Slater
toslink into Dirac Live box, & 3 minidsp 2X4 HDs
Focal 4 ch bridged to HLCDs
2 JL audio 600/4 bridged mid midbass
jl audio HD1200/1 Sub
clairion NX706 96k Nav Screen
HE Horns, Mids, Midbass bEYMA, b&C
You want very low latency… and an acceptable ADC , 24bit or better
Low latency is key for measuring
