AustinJerry
- Jun 5, 2017
- 223
It seems to me that REW is very particular with respect to its connection to the mic, in my case a USB UMIK-1. When the mic is connected prior to launching REW, it performs as expected, showing ~50dB noise floor when opening the SPL meter. If, however, the mic is accidentally unplugged during an REW session, and then re-connected, the REW SPL meter shows a +30dB noise floor. There seems to be no way to recover from this situation other than to exit and re-start REW. And in another case, if REW is started without the mic being plugged in, REW refuses to recognize the mic if it is subsequently plugged in. Once again, the only recourse is to exit and re-start REW with the mic plugged in ahead of time.
Have I got this right, and is this expected behavior? I often hear of other REW users confused by situations in which the mic measuring level increases unexpectedly, or where users are having trouble getting the mic recognized at all. I would like to be able to provide the appropriate guidance.
