anjunadeep
- Aug 19, 2019
- Messages
- 17
Hello! I was posting in the REW thread on AVS and a member messaged me and suggested I ask it here as it may be more in this forums wheelhouse.
I have a pair of subwoofers on order that should arrive in another couple months, but I thought I'd take the time to use my little JL Audio E110 to try some new placement options and see how they summed up. This little lass is sure easy to move!
So I tried a bunch of different locations and picked what seemed to be the three best spots individually, and then tried summing them in various combinations. Here is the results (individual measurement colors correspond with the color box/subwoofer in the image and the trace arithmetic sum is labelled by hand):
Here is just the sums overlaid for easier comparison:
"A" certainly has the most headroom below 40Hz, by far, until we meet at 20Hz. Perhaps this is because with both subwoofers aligned on that front wall they are coupling like an array? "A" is the worst in the 43-52Hz region though, and there is a tight null at 56Hz or so (I've heard those aren't really audible though). "C" has the best midbass headroom, but it seems really down around the crossover and in the deeper bass.
The interesting thing is this does seem to be pretty accurate, because I have the 1/3rd and 2/3rd along the wall uncorrected measurements from my previous ported duals and it looked like this:
My biggest gripe with this positioning was that 45-55Hz range. However, if I just replace that problem with 30-35/38Hz, where my house curve is greater, not sure what is better...
With my old setup, this was the pre and post EQ measurements. You can see I did have some success boosting that null, but it was headroom limited. I'm hoping my new subwoofers have considerably more headroom there, so maybe I could power through that - but I was hoping to find better placement for the second sub. There was nothing I could do about the null at 57Hz, so I didn't even attempt to EQ that... but the bigger dip at 45Hz-52Hz or so I did have some success boosting.
Questions:
Is my investigation worthwhile? Can I use a small sealed sub moving around the room to get an idea where to place two giant sealed ones?
Why when I sum responses, does the output actually go DOWN in some circumstances? Is this from cancellations? I.e for option "C" the individual outputs look very smooth between 30-40Hz, but when summed the summed total is less!? Is that something I could fix with delay? How would I figure that out?
Thanks for any help!
Questions:
