Privatier
- Oct 17, 2022
- Messages
- 4
- SPICA
I had used REW for several months on my desktop computer with Linux Mint 20 without problems, until a few days ago the output signal has always been 30dB smaller than the level set in the generator or measurement setup. My voltmeter shows the much smaller signal, and REW displays the corresponding much smaller input voltage. I have done a "delete preferences and shutdown", uninstalled and re-installed REW, no change. Other sound applications work just fine, like playing a sinewave signal produced by sox or saved from the REW generator. Running REW in a different user account on the same computer works just fine. Utilities like amixer or pavucontrol do not show attenuation anywhere. Any hints for other settings and tests are very much appreciated.
