It would be good if all relevant revision info was in the "About" and that that window was possible to copy past.
5.20.14ea8 ?
REW V5.20.14 running Azul Systems, Inc. JRE 1.8.0_352 64-bit on OS X 10.15.7 Locale: language en, keyboard , UTF-8 at 110 DPI
Message:
java.lang.IllegalArgumentException: Width (0) and height (0) cannot be <= 0
Stack Trace:
Width (0) and height (0) cannot be = 0
java.awt.image.DirectColorModel.createCompatibleWritableRaster(DirectColorModel.java:1016)
java.awt.image.BufferedImage.<init>(BufferedImage.java:333)
roomeqwizard.qC.A(y:1094)
roomeqwizard.wC.A(y:333)
roomeqwizard.wC.B(y:587)
roomeqwizard.wC.A(y:2406)
roomeqwizard.wC.A(y:2647)
roomeqwizard.wC$12.actionPerformed(y:2640)
javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:262)
java.awt.Component.processMouseEvent(Component.java:6539)
javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
java.awt.Component.processEvent(Component.java:6304)
java.awt.Container.processEvent(Container.java:2239)
java.awt.Component.dispatchEventImpl(Component.java:4889)
java.awt.Container.dispatchEventImpl(Container.java:2297)
java.awt.Component.dispatchEvent(Component.java:4711)
java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
java.awt.Container.dispatchEventImpl(Container.java:2283)
java.awt.Window.dispatchEventImpl(Window.java:2746)
java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
java.awt.EventQueue$4.run(EventQueue.java:733)
java.awt.EventQueue$4.run(EventQueue.java:731)
java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
java.awt.Dialog.show(Dialog.java:1084)
java.awt.Component.show(Component.java:1671)
java.awt.Component.setVisible(Component.java:1623)
java.awt.Window.setVisible(Window.java:1014)
java.awt.Dialog.setVisible(Dialog.java:1005)
roomeqwizard.wC.A(y:1223)
roomeqwizard.tB$3.actionPerformed(y:1176)
java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
