Editor / Senior Partner
- StormAudio ISP.24 MK2
- Main Amp
- Emotiva XPA-5
- Additional Amp
- Emotiva XPA Gen3 2.8 multichannel amp
- Other Amp
- Denon X8500H
- DAC
- THX ONYX
- Computer Audio
- AudioEngine A2+
- Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
- Streaming Equipment
- iFi Audio Zen Blue
- Streaming Subscriptions
- Spotify
- GoldenEar Technology Triton One.R
- Center Channel Speaker
- GoldenEar Technology SuperCenter Reference
- Surround Speakers
- GoldenEar Invisa MPX
- Surround Back Speakers
- Front Height Speakers
- SVS Prime Elevation x4 (Top Front, Top Mid-Front)
- Rear Height Speakers
- SVS Prime Elevation x4 (Top Middle, Top Rear)
- Quad Array SVS SB16s
- Other Speakers
- Behringer 1124p; Aura Bass Shaker Pros; SuperSub X
- Screen
- Seymour Screen Excellence, Enlightor NEO AT Screen
- Video Display Device
- JVC NZ8
- Other Equipment
- Sony 65-inch A95L OLED
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
Lenexa, Kan. – February 23, 2026 — Exposed-structure ceilings have moved from trend to standard across retail, hospitality, fitness, and mixed-use commercial spaces. With that shift, audio system design has changed as well. Instead of concealing loudspeakers in drywall ceilings, integrators and consultants are working within open architectural environments where hardware is visible, and acoustic conditions are less predictable.
The result is renewed attention on coverage control, intelligibility, and installation efficiency.
In open-ceiling applications, audio systems must perform in spaces that often feature higher ambient noise levels, reflective surfaces, and flexible use patterns. Restaurants may transition from daytime background music to evening entertainment. Fitness centers operate at consistently elevated volume levels. Retail environments rely on distributed messaging and music for brand reinforcement.
In these environments, the design objective is rarely maximum output. More often, it is achieving uniform coverage without hotspots or dead zones while maintaining a clean architectural presentation.
Distributed pendant loudspeakers have gained traction in response to these demands. Suspended from exposed ceilings, they provide predictable coverage geometry and allow system designers to maintain consistent spacing and output across large areas.
SoundTube’s RS600i pendant loudspeaker is engineered for this category of application. The two-way, ported open-ceiling design incorporates a 6.5-inch polypropylene woofer and a 1-inch convex titanium tweeter with Ferrofluid cooling, mounted to a proprietary cast-aluminum baffle and heat sink. The system delivers usable low-frequency extension to 58 Hz (±10 dB) and maintains a consistent 100° dispersion pattern across the critical 2–10 kHz range, independently verified.
The dispersion characteristic is central to its application. In open-ceiling environments, maintaining uniform high-frequency coverage is essential for speech intelligibility and balanced music reproduction. The RS600i utilizes SoundTube’s patented BroadBeam® waveguide technology to maintain consistent off-axis performance across the listening area. Combined with patented ZeroReflection™ enclosure technology, the design supports cabinet rigidity and controlled acoustic behavior in exposed installations.
Measured sensitivity is 88.5 dB (1 W / 1 M), with 90 watts continuous power handling and maximum output of 108 dB at 1 meter. This performance profile positions the loudspeaker for background to mid-level SPL environments where clarity and even distribution are priorities. A six-position selectable tap switch supports 25V, 70.7V, and 100V distributed systems, with a transformer bypass position for 8-ohm operation, allowing flexibility across commercial project types.
“The challenge in open-ceiling design isn’t simply achieving sufficient level,” said Peter Melvin, Vice President at SoundTube. “It’s delivering consistent coverage in spaces where ceiling height, reflective materials, and changing use patterns all influence how sound behaves. Dispersion control becomes a design tool.”
Installation considerations also factor into specification decisions. The RS600i includes UL-listed galvanized steel hanging hardware with integrated SpeedClamp™ self-locking cable grips and a secondary safety cable, along with a Euroblock connector and weather-resistant terminal boot. The injection-molded, glass-reinforced ABS enclosure and powder-coated steel grille are designed for durability in both indoor and outdoor installations.
For projects requiring extended low-frequency performance, the RS600i may be paired with SoundTube’s RS1201i-SuperT™ subwoofer. The subwoofer delivers low-frequency response from 32 Hz to 200 Hz (±10 dB, independently verified) and peak output of 113 dB, enabling integrators to scale distributed systems for more music-forward applications without altering overall coverage geometry.
The RS600i is available in black or white finishes through SoundTube’s authorized distribution network.
For more information, visit SoundTube Entertainment®.
