The most cost-effective way to add lots of high quality bass to a HT setup recommended here and elsewhere, is to make DIY subwoofers, getting largest diameter speaker available (15" or 18" if not larger), build an enclosure based on T-S parameters of the speaker and pair it with an outboard amplifier and a miniDSP.
The prospect of making an enclosure by myself is daunting. I don't have ready access to woodworking tools and fixing a mistake would be costly, so I was looking at the options available to me in Europe (sadly, I don't see premade subwoofer enclosures for home use, in contrast to the US).
I recently came across listings of lightly used or even unused (due to COVID) stage subwoofers. The price range is incredibly low like $150 for a pair of Wharfedale Pro SVP-18B up to $500 for a pair of Wharfedale Pro Delta X18B in perfect condition. The 18-incher in DLX series (released in between these two) is somewhere in between cost-wise.
Looking at Wharfedale's page for X18B here, the frequency response is 38 Hz-1.5 kHz ±3 dB, then goes down to 30 Hz at -10 dB. I figure if it's a major third down for each -7 dB, it would go to 24 Hz at -17 dB and just below 19 Hz at -24 dB, all at 99 dB. Pretty solid.
Looking at its manual, no reflex ports are visible, so it's probably a sealed speaker. The older model SVP-18B has three ports on the front, this one doesn't.
I won't be playing the subwoofer at 99 dB, I figure the peak SPL they ever reach is 100 dB, and will usually be played at no higher than 85 dB.
Anyway, aesthetics aside, I was thinking any of these large sub-bass units could be an excellent subwoofer in the home theater when paired with a 800 W amplifier and supplied through a miniDSP.
It seems like such an easy solution that begs to be paired with something like Behringer NX1000 or NX3000 amplifier and a miniDSP 2x4. A cosmetic cover would probably be necessary to make it living room-compatible, but it's not impossible.
What am I missing? Are DIY solutions, sometimes costing several times more per speaker, better in any tangible way, considering it's bass we're talking about?
