theconqueror
- Feb 11, 2022
- Messages
- 8
- Denon AVR-660H
- JBL530
I have my receiver (Denon 660H) subwoofer settings set for LFE + Mains. When I use the system normally the subwoofer works just fine, but when I try to run a sweep in REW the two fronts work, but the subwoofer doesnt. I'm currently using the java drivers as I just have two fronts and the subwoofer. Any suggestions? Including the REW file incase that helps.
I just got my first real "home theater" setup and my dad lent me his Definitive SC8000 sub to try out. It sounds...odd. Even on the lowest volume it sounds loud and doesnt blend too nicely with the mains. I figured I would try out REW and see if there was anything I could see.
PS - this thing has an 8" driver. You people telling me I need two 21" subs might be crazy or I'm blissfully rolling in my ignorance
