Kvach
- Dec 11, 2023
- Messages
- 2
- DAC
- Tascam us-366 Roland edirol fa-66 Focusrite saffire pro 24
- Yamaha NSg 40 GRUNDIG FINE ARTS BX-1
Where can I find measurement specifications, does anyone know links to current documentation?
For example, is it possible to measure the noise level of a sound card with a gain ratio of 1 to 1? (assume the input is ideal and measure only the output)
How is dynamic range measured? i.e. 32 bit integer pcm dr=192 dB , but OVP can add analog clipping at lower amplitude, then i can find max volume without clipping and dr=max vol - noice level and signal to noise ratio = max volume/noice level ?
