Loopback Accuracy Distance Measurment
Sonder
Hello, I am just wondering how accurate should the readings be from speaker to microphone, mine always seem to be out by 5 are 6 cm, is this OK?
Below is the readout but the actual distance from mic to speaker is 20cm
Delay 0.7016 ms (241 mm, 9.47 in)
relative to Loopback with no timing offset
There may be additional delays in the replay chain accounting for the extra time taken for the signal to arrive at the mic.
EarlK
That (@2" ) differential is about right ( for a small speaker ).
The "Time of Flight" will always include the delaying effects of any crossover ( specifically inductors ) as well as the drivers voice-coil inductance ( which is another coil in series with the Low-Pass inductor ) .
These coils add their inductance together to produce measurable delay to the signal being propagated ( created ).
That means the measured acoustic signal will just about always emanate from somewhere behind a drivers diaphragm ( and sometimes even behind the voice-coil if it's really large diameter ).
Sonder
Many thanks for the answers, helps a lot in understanding the physics.
