mcmidi
- Jan 6, 2021
- 1
- Reußenzehn Tube Preamp
- Main Amp
- Focal Shape 50 active monitors
- DAC
- Behringer UMC404HD
Hi,
I use my MacBook to stream from Qobuz directly to an audio interface and active monitors. Now I woud like to check my room conditions with REW. I`ve learned, that I can export the analysis to an text file. Now I would like to use an EQ on my Macbook to optimize the sound. For that I would like to use an stand alone EQ AU Plugin, like you us in Logic Pro X as an Audio Unit. Can some one suggest an EQ AU and/or is there an AU, which can directly import the text file from REW with the analysis results?
