Klipsch Reference Premiere RP-600M II - Novice's Hot Take
Jefferad
Due to some shifting around of some of my current AV equipment inventory in my home, I ended up with an "extra" receiver and decided I'd like a simple 2 channel setup in my home office to enjoy some music between conference calls. I wasn't really interested in spending more than about $200-300 as I have 2 other setups in rooms for movies / music that I'd rather make upgrades to if I were spending bigger dollars. Spent a couple of months on Facebook marketplace and other places in search of some used bookshelf speakers that might be more in the $500 range new. No luck - everyone was charging way to much (in some cases more than current sale prices I saw). On Slickdeals.net, I saw that Acoustic Sound Design products had RP-600M II's on sale for $299 including free shipping. These are on the Klipsch site at $649 msrp but on sale for $499. Did some checking around of "print" and video reviews and by the time I went back to pull the trigger, they were back to the original msrp price. But, I setup an alert and 2 weeks later they popped up again. I didn't even pause a minute before placing my order. I'm not at all an expert, but thought I'd share my novice hot take on my experience with them over the past month+.
Setup
  • Ebony RP-600 II pair
  • Receiver - older Sony STR-DH550
  • Sub-woofer - No
  • Room - Approx 12x12, 8 ft ceiling, Vinyl tile flooring, all hard surface - no rugs or fabric furniture
  • Music source - running my laptop through HDMI to play Spotify
Order, Delivery, and Unboxing
  • ACD website was fine, though info and pics were a bit limited and I was worried I might be getting 1only speaker or something - based on other postings on Slickdeals, I went ahead anyway
  • Took about a week to arrive (ordered on a Friday and arrived the following Thursday)
  • Tracking wasn't the easiest to access from the ACD website as the "track" link just took me to a login page - perhaps user error, not sure. But it came UPS and I got notifications from UPS directly due to having an account there.
  • Was in a big, unbranded box, with a smaller branded box inside. Had form fitting flexible foam to hold the speakers. Well packed imho.
General appearance and Feel
  • Not fancy, but straight forward and attractive.
  • Ebony is dark with light oak-looking light gray grain.
  • Front of the enclosure has a picture frame style bevel for about 1/2 that provides some visual interest leading down to the speaker grill.
  • Woofer has that classic Klipsch copper color with a complementary copper colored ring around both the woofer and tweeter. Makes you want to run without the grill!
  • Grill is attached by 6 small magnets - super easy and I love it so much more than posts that break on other speakers - don't ask me why I say that ;-)
Sound
  • As stated, I'm not an expert, so not always sure how to describe what I'm hearing, but with that in mind...
  • These sound great to me! I was worried that they wouldn't pack the bass punch I wanted without a subwoofer since I didn't want to add that to the setup ($)
  • Top end is bright and clear. I had to turn up the bass on the receiver equalizer settings, but once I did, these really thumped.
  • It's a small room and I don't have a lot of space which is both good and bad. I found that I had to be around 8 feet away to hear the full frequency response for most things. Standing up was more forgiving than moving left or right from center.
  • In particular, I noticed that when I'm closer, the bass really disappears. Decided I need a set of speaker stands to give the distance needed as I have them sitting on each end of my L shaped desk at the moment.
  • Also, I find that I have to turn up the volume a bit more than is comfortable for background music to really get the most detail out of them. Classical sounds good at lower volumes, but to appreciate Metallica or Muse fully, it really likes to be turned up.
  • Only criticism I can offer is that I can sound a bit hollow to my ears sometimes. Not sure if that is my receiver and / or can be EQ'd out.
Bottom Line
  • I'm unbelievably pleased with what I got for $299. No subwoofer needed for casual music in a relatively small space.
  • Have you had a listen to these? Does any of this resonate with your experience?
Setup
  • Sub-woofer - No
Sound
Bottom Line
View attachment 82781View attachment 82782View attachment 82783
Great deal you got for a pair of these.
Here’s a review with measurements. Your comments are pretty much in line with them. The lack of bass when you’re closer is probably a room effect. (a bass null in that area due to standing waves aka room modes).
My son has an older version of these he uses on his vinyl set-up. Sounded good to me :) Enjoy!
Cool setup... love the idea, as I have a similar setup.
There is a computer program for EQ... can't remember the name of it. I've used it in the past and it works well.
It would help to know what kind of laptop you are using so we could suggest a Room Correction and/or EQ solution...
Although your Receiver appears to have some onboard EQ you might look into using something like The Hang Loose Host which makes orchestrating DSP Plugins dead simple... https://accuratesound.ca/hang-loose-host-hlhost/
I’ve never used anything like this… at its core, it’s DSP that you set up on your laptop, post source app, using a loopback function?
Are you tasked with taking measurements with REW and then manually adjusting settings within Hang Loose to craft a room specific target curve?
@Todd Anderson, The Hang Loose Host is basically a software patch panel that routes your system sound input through one or several VST DSP plugins and back through your systems sound output... This "hosting" of various VST DSP plugins gives you a method to string together things like Room Correction, and/or various professional signal processing utilities like any number of software emulation Equalizers, etc...
Literally thousands of plugins are available... Here are a few... Lol... https://www.kvraudio.com/marketplace/
If you are using Convolution to do Digital Room Correction you would use a tool like REW to do room measurements and then create FIR filters that you would load into a convolver... If you are using one of the many other Equalizer emulations you would measure your room with a tool like REW and then use one of the output filter types that may match the Equalizer emulation you are using or you might need to manually adjust the Equalizer emulation you are using interactively... There are a lot of options using this "hosting" method... Including, and not limited to, creating crossovers for bi-amping/tri-amping... Any music player application like Roon, Audirvana, Spotify, Youtube etc that sends its output sound through the system is now processed through this HLHost signal chain...
Here is an example using the HangLoose Convolver for Room Correction DSP using FIR filters and then using a Dynamic Equalizer to add a little sauce to taste...
