The Hyperion Series is not a single product, but a full ecosystem. It includes a 16-channel immersive surround processor, a lineup of multi-channel amplifiers, and a set of eARC to Dante converters designed to tie everything together. At the heart of the lineup is the APR-16 surround processor. Designed in-house, it targets complex home theater installations where flexibility and precision matter. The 16-channel platform allows integrators to independently optimize signal paths, giving them control over how each channel behaves within a room. On the hardware side, it leans on 32-bit ESS Sabre DACs and supports up to 24-bit 192 kHz audio, paired with a full set of analog outputs and routing options that make it adaptable to a wide range of system designs.
Video and control are part of the equation as well. The APR-16 incorporates HDMI capabilities designed for reliable source and display compatibility, along with HDCP and EDID management to reduce the friction that often comes with complex installs. There’s also a built-in API for integration with control systems, a key feature for custom installations.
Networked audio is where the platform starts to separate itself. Dante and AES67 support are built in, allowing audio to move across standard network infrastructure instead of relying solely on analog connections. The processor even includes a built-in four-port Ethernet switch with Dante and AES67 capability, configured as two inputs and two outputs. That added flexibility can simplify deployment in multi-room or distributed audio environments while keeping networked audio routing more predictable. Dante functionality is set to expand to 16 channels through a future firmware update, pointing to a platform that’s designed to grow alongside evolving system demands.
On the amplification side, AudioControl is introducing three models under the Hyperion name. The Tetra, Penta, and Hepta deliver four, five, and seven channels of amplification, respectively. Each model is built on AudioControl’s G4 Class H architecture, which delivers high output while managing heat more efficiently than traditional Class AB designs. In practical terms, that means more power in a manageable form factor, something that matters in densely packed equipment racks.
AudioControl’s LightDrive circuitry is also part of the design. This system monitors for clipping and steps in before distortion reaches the speakers, preserving dynamic range while protecting hardware during demanding playback. It’s one of those features that tends to stay out of sight, but becomes important when systems are pushed hard during real-world use.
Like the processor, the amplifiers are built with integration in mind. Balanced XLR inputs, unbalanced RCA inputs with pass-through, heavy-duty 5-way binding posts, and a 12-volt trigger make them easy to drop into existing control environments. Native Dante and AES67 support extends that flexibility further, allowing amplifiers to be deployed as part of fully networked audio systems rather than being tied to traditional analog signal paths.
Rounding out the lineup are the Hyperion Axis converters, designed to bridge the gap between display-based sources and networked audio systems. Available in two-channel and ten-channel versions, these units extract high-bitrate audio from eARC or digital inputs and route it directly into Dante and AES67 networks. The Axis10 goes a step further, offering onboard decoding for up to eight channels of Dolby Atmos or DTS-HD formats, along with processing tools like EQ, crossover, delay, and gain control. The idea is to move more functionality closer to the edge of the system, reducing reliance on centralized processing where it’s not needed.
Taken together, the Hyperion Series reflects a broader shift in system design. Instead of building around isolated components, the focus is on creating an interconnected platform where processing, amplification, and distribution work together seamlessly. That approach aligns closely with the direction the industry has been moving, or at least pushing, especially as network-based audio continues to gain traction in high-end residential and custom installation spaces.
More information is available at audiocontrolpro.com.
Related Reading:
NEWS: From the Ground Up: AudioControl’s Hyperion Series Breaks New Ground and We've Got the Juicy Details!
NEWS: AudioControl New Hyperion Series Debuts with Dirac Live Active Room Treatment at CEDIA 2025!
NEWS: AudioControl Debuts the Bijou Series: Compact, High-Performance eARC Amplifiers
NEWS: StormAudio Introduces Impulsion 8, a Fully Digital Amplifier for Immersive Systems
NEWS: StormAudio Firmware 4.7r2 Arrives with a New Web Remote and HDMI Improvements
