I just got a minidsp 2x4HD, umik and rew. When I run sweeps from 10-180, I get nothing from my 4 subs until about 60Hz. Then it jumps up like a big hill. I get the same thing from all 4 of my subs individually and in groups. For the first couple of seconds the minidsp shows no input and then the bar shoots up. It seems like the signal is being cut at the lower frequencies. Maybe a high pass filter. Everything in the minidsp is set to bypass. I'm using a yamaha 3050 receiver and the same thing happens with ypao on and off. I've tried moving the crossover up to 200 for all speakers and all are small. All 4 of my subs should go down below 20. For example I get the result from a hsu vtf-15h mk2. I've tried moving the umik around.
I have to wonder if the receiver is filtering out everything below a certain frequency except for LFE signals and rew is sending analog instead of LFE. Just a thought.
Any help is appreciated.
