Mark Wilkinson
- Jun 9, 2017
- Messages
- 10
The Scope is great
Been using it to capture Wavelets via the Generator's Tone burst capability, playing with the technique presented in this article.
https://www.prosoundtraining.com/2019/07/26/signal-aligning-using-wavelets/
The wavelets are proving to give very repeatable times-of-flight even at 40Hz etc. So i'm trying to delve into them a bit.
Is there a way to compare scope traces by saving them, where they can then be imported back into REW as impulses?
I've tried the Scope Export button, and then import that as an impulse with no luck. (Also tried truncating the first 15 lines of info in the text file, not knowing anything else to try....)
Or simply save the scope image for overlay with another capture?
Thanks !
Thanks !
