Thanks!! I thought that was the case. I'm new and just spent a lot on speakers and filled the living room. I was hoping I didn't have to buy a dsp. My wife but her foot down.REW just calculates the EQ filters. Some other device in the signal chain is needed to enter them into and use them. MiniDSP is the most popular for this. If you go to the EQ section of REW it lists many devices to generate filters for. Some AVRs and processors will also work with PEQ filters.
I have tried to use the manual function but its very limited. I'll have to wait for my wife's approval to buy a minidsp so I can import the rew eq file. Thanks for the help!!!!!!!In another thread you suggest your AVR is a Onkyo TX-SR805, which has Audyssey MultEQ XT eight-point auto setup and room calibration system... I would guess that there is a way to manually set this room calibration system utilizing filters created with REW...
Just the sub. Fortunately I've got a decent response as is. But I have some 5db dips followed by some 5db peaks. That I'd like to flatten out. ThanksJust to be sure we are on the same page, are you wanting to EQ the sub(s) only or all speakers?
