rpschultz13
- Apr 5, 2026
- 4
Hi, new to REW. I'm using REW through a Motu M4 on a Mac.
I'm testing an acoustic guitar preamp that I've designed, it has TS input/output.
Thanks!
- I read (AI) that going from unbalanced to balanced I should float the RING of a TRS on the OUTPUT of the M4 into preamp, but simply use a TS cable between the output of the preamp and the INPUT of the M4.
- I calibrated it at -12dBFS, I measured 72.5 mV. This seems low, and in the generator it won't let me put in a signal more than 289 mV, which is 0 dBFS. M4 says it can output +16 dBU which is +/-3.6V. Why won't it let me output more? Not sure I need to, just wondering.
- After doing this calibration, I measured THD at 3 different preamp gain levels (top left knob), see below.
Thanks!
