Hello,
I see from some release the house curve file is no longer set in preferences but in the EQ dialogue. But the chosen house curve file is still saved as a global REW setting.
I always wished REW could save it per mdat/project file. Since such projects may not be related to each other at all having the need for different house curves.
I'm always confused using an mdat file after a longer time when showing a house curves that I used in a different project. I then have to remember which house curve I used with this mdat.
Or is there some kind of workaround? Would be great.
I really learned to like REW very much
Many thanks
Many thanks
