In need of help, Inconsistent levels in sweep and SPL
GriffinO
Denon 4700
Klipsch RP-280
Klipsch RP-504c
Dual Monolith 15"
When using SPL my readings will drop from 80db down to 30db with no changes in position or volume on AVR also when doing sweeps I do a volume check and I get the ok then do a sweep and volume is too low. When I check volume again it is low but after 5 to 7 checks the volume comes back.
Might be some form of noise cancellation processing. If you are on Windows make sure enhancements are not enabled on the audio input properties Advanced page (System - Sound - Related Settings on right hand side - Sound Control Panel - Recording - select UMIK, click Properties button).
