REW Generator function works fine (sound from speakers). RTA (and SPL Meter) works fine (shows sound when manually making noise into the mic). But simultaneous use of Generator and RTA (or SPL meter) doesn't work - it complains there is no input signal. And "Check Levels" doesn't work in Preferences for the same reason.
Machine is windows 10 with attached USB Presonus AudioBox for both input and output (mic is ECM8000). In the past I've used REW with this same AudioBox (for output), but with a UMIK-1 mic on a different USB port without issues, but I don't have that mic right now. Also, I've used this AudioBox successfully for simultaneous I/O with other apps. Is this a known issue with REW?
