iFi Audio Introduces GO link 2, a Tiny DAC Designed to Improve Phone and Laptop Audio
(March 5, 2026) For anyone who has spent time listening to music directly from a laptop or smartphone, the limitations of built-in audio hardware are often easy to overlook. It works, it’s convenient, and for casual listening, it usually lands in the realm of good enough. But as lossless and high-resolution streaming continue to spread across services like Spotify, Apple Music, Tidal, and Qobuz, that baseline level of audio performance can quickly become the weak link in the chain.
That’s the gap iFi Audio is aiming to address with the introduction of the GO link 2, the latest version of its ultra-compact USB dongle DAC designed to bypass the internal audio circuitry found in phones and computers. The device connects directly to a USB port and routes the digital signal through its own internal converter and headphone output stage, effectively turning the host device into a portable high-resolution music source.
Physically, the GO link 2 continues the same minimalist concept as the original model but pushes the portability angle even further. According to iFi, the new version is 8% smaller and 29% lighter than its predecessor, making it the most compact DAC the company has produced to date. And with that size, ease of use is also streamlined to the simplest level: simply plug it into a phone, tablet, or laptop and instantly improve the quality of headphone playback without adding bulk.
Inside the small chassis sits an ESS Sabre DAC chipset capable of handling PCM audio up to 32-bit/384kHz, along with native DSD256. That level of support goes beyond the requirements of most streaming platforms, but it leaves room for locally stored high-resolution libraries and future streaming developments.
iFi has also introduced several performance enhancements to improve overall playback quality. One of those features, called Dynamic Range Enhancement, increases the available dynamic range by roughly 6dB. In practical terms, that means greater contrast between quiet passages and louder peaks, which can help music feel more expressive and less compressed during playback.
Another update focuses on distortion reduction. By adjusting correction parameters within the DAC chipset, the GO link 2 reduces second and third harmonic distortion components, with iFi claiming up to a 62% reduction compared to the original GO link model.
The device also incorporates the company’s proprietary S-Balanced output stage. Balanced headphone circuits are typically used to reduce channel crosstalk and signal noise, but they usually require dedicated balanced headphone connectors. S-Balanced applies similar design principles to a standard 3.5" single-ended output, which iFi says cuts channel crosstalk roughly in half while maintaining compatibility with conventional headphones and in-ear monitors.
Another addition is compatibility with the iFi Nexis mobile app. Through Nexis, users can perform over-the-air firmware updates and select between two digital filters, Hybrid and Linear, to subtly adjust the DAC’s sonic character. The app also enables optional volume limiting. At launch, Nexis functionality is available only on Android devices.
The GO link 2 is now available on iFi’s website and through authorized dealers, with a retail price of $59 in the United States, £59 in the UK, €69 in Europe, and $89 CAD in Canada.
https://www.avnirvana.com/media/ifi-go-link-2.10738/full?d=1772735342
Related Reading:
