Myashi
- Jun 2, 2021
- Messages
- 4
- Main Amp
- Fiio EK 10
- DAC
- Fiio Ek 10
Hi!
As the title says, I'm having trouble to make it work REW.
Following a guide on EQ APO, it seems that REW is important to make a config file for EQ APO.
I'm a total newbie, and I never heard of both the apps. The problems with REW starts as soon I click on Measure. A pop up who ask for a SPL, appears.
I try to calibrate using REW speakers, from the drop down menu and an error message says: no sound card input data -> the sound card did not provide any input data from SPDIF Interface (FIIO EK10) Volume Master (Volume master), please check that it is connected.
If I close and reopen REW, then click on: continue anyway, the same message shows-up again. I believe that is because in Preferences/Input Device, I set the Fiio EK!0 (a dac amp combo that I use as ext audiocard).
I set back the Input Device, on Default Device, and whatever I do, I always get this message: no sound card input data -> the sound card did not provide any input data from Default Device, please check that it is connected.
I tried to follow some suggestion I read on the forum Home Theater Shack, and I didn't understand much if not I would have needed, the last beta REW (that I'm using) and if I get it right, the whole problem is that I don't have a microphone.
I hope I'm not bothering anyone, but can someone help me?
