shaunp
- Oct 15, 2022
- Messages
- 2
- DAC
- Focusrite Clarett+ 8pre
- Kali Audio IN8v2
- Other Equipment
- Beyerdynamic MM-1 microphone
Hello,
I've just started measuring with FDW enabled to filter out reflections from my measurements and hoped I could ask for some help.
-I don't know what FDW values to use, so currently I'm just plugging in values from any guides I can find online. Is there a way to check or dial it in and get confidence? Offhand, I think I should check the impulse response and confirm reflection spikes are eliminated if the settings are good. Other than that, is there anything else I should do or other criteria I should check?
-I saw my measurements have 1/48 smoothing applied automatically after enabling FDW. I'd like to export the measurement without smoothing (to Rephase), but selecting 'Remove smoothing' still leaves 1/48 smoothing enabled. Is there a way to do this? My 'width in cycles' is set to 15. Other info is that 'Allow 96 PPO log spacing' is unchecked, but my measurement info shows 'Freq spacing is 96 PPO.
Thanks,
Shaun
BTW - I'm new and really enjoying REW
Thanks,
Shaun
