How to check multi phase traces at the same time?
Johnson Chow
When align subs with full range, it is common to compare the difference between their phase traces at the cross-over range. In REW, how can I look at phase traces of different measurements at the same time on one plot? Just like the All SPL can show multi SPL traces at the same time.
Thanks folks!
JStewart
Central FL
To see phase traces on one chart you can use overlays.
You might want to check out the REWs alignment tool if not already familiar. It can be accessed from All SPL Chart. Choose controls. Choose alignment tool.
