How to apply a measured compensation EQ curve into a DAW that is using ASIO?
Sacco_Belmonte
I'm awaiting my UMIK-2 I recently ordered.
Now about REW and DAWs:
I know I can use EQ APO in a directsound device. That's out of the question. (will do to my system sound device)
But what about a DAW using ASIO? (ASIO bypasses directsound)
Should any decent convolution plugin do the trick? Do you have any recommendations?
System is:
5900X 64GB RAM muscle based workstation PC
TASCAM 16x08 interface
Presonus Monitor Station v2
Genelec 8040a
Thank in advance.
Sacco_Belmonte
Solved.
Any decent convolution plugin works just fine.
Although is better to EQ manually cause room correction, while good, it can make your room too flat.
So what I did was to measure my room (5 takes at slightly different positions) , take the average and make correction filters, apply to EQ APO and tweak it a bit (mostly the far ends not as flat).
Then replicate the EQ in APO in a EQ2 in FL Studio.
Seems like room correction is not an absolute thing (for non scientific tasks) and there is a bit of taste involved. At least for music composition/mixing.
