How can I calibrate my system with a microphone calibrator?
tcoor8325
I would like to calibrate my microphones to dBSPL using a mic calibrator, inside of REW
I have a GRAS 45CA Ear Simulator that I am using to make headphone measurements. The device comes with a GRAS 42AA Pistonphone Microphone Calibrator, which produces 114 dBSPL (linear) at 250 Hz.
Before switching to REW, I was using the Audiomatica CLIO 12, which allows me to calibrate my microphone by setting a calibration level to expect, and then calculates a sensitivity by recording the signal when the calibrator is on and inserted over the microphone (See image below).
My question is, how can I do this within REW? My 1st thought is that my sensitivity will have to be in dBFS instead of dBV. I could perhaps measure the waveform when the calibrator is on with the Scope. I'm also not sure if I should make a cal file, because they appear to measure sensitivity w.r.t. 94 dBSPL.
My current rough calibration has been the standard method for room measurements using an SPL Meter and the replacement method.
My system is as follows: GRAS 45CA Left and Right Microphones -> Preamplifier -> Focusrite Scarlett 2i2 -> Thinkpad X1; Ubuntu 22.04.5 LTS; REW V5.31.3
Thanks for any guidance!
Thanks, this solved it. My procedure for those wondering:
  1. Open up the ear simulator to access the left microphone
  2. In REW, under SPL Meter->Calibrate, set reference to 114dBSPL and hit start
  3. turn on pistonphone and place over microphone
  4. REW records measurement
  5. Under Preferences->Mic Cal Files->Settings, REW has already calculated the dBFS @ 94dBSPL. Record this for future use (REW should save this value by default)
  6. Repeat for Right Ear
    To calibrate your audio system, use a calibrator matching your microphone's specifications. Follow REW or other software calibration procedures for accurate audio measurements. My part-time job and university workload were too much to handle, so I searched online for help. That’s when I found https://ukwritings.com/ This platform offers excellent essay writing services, perfect for students who want to stay ahead without stressing out. UKwritings's team of professional writers understands UK academic standards, which made the final result both accurate and high-scoring. It’s definitely a go-to option for students facing tight schedules.
Thanks for the steps.
