House curve and crossovers
slayer38115
JL Audio VX1000/5i
Focal 165K2P
Focal PS 165FE
Amazon Music HD
Does REW have a way to take a pre existing house curve and apply crossovers to it. Example, I want to measure my 6.5" separate from the tweeter. Using the Audiofrog house curve, can I use REW to apply a 24db LPF at 3khz and have the house curve display reflect the crossover with slope so I match just what the midbass frequency range is. Then do the same with a HPF at 24db 3khz for the tweeter.
slayer38115
JL Audio VX1000/5i
Focal 165K2P
Focal PS 165FE
Amazon Music HD
So I found a way by taking the house curve and going into EQ, then instead of choosing bass limited speaker, I choose speaker drive which allows me to add HPF and LPF. Then I choose "generate measurement from target shape". Seems to work. Is the best way to way?
