rajopotamus
- Jul 7, 2021
- 10
- Monolith HTP-1 16 channel processor
- Main Amp
- Monolith 9x
- Additional Amp
- Monolith 5x
- Streaming Equipment
- AppleTV 4k, Firestick 4k
- Monolith THX 465
- Front Wide Speakers
- Monolith THX 365IW
- Center Channel Speaker
- Monolith THX 465
- Surround Speakers
- Surround Back Speakers
- Front Height Speakers
- Monolith 365IW
- Rear Height Speakers
- Monolith 365IW
- Monolith THX 15 x 4
- Video Display Device
- LG HU810pw
Hello All-
Part 1:
I wanted to pick your brains to help resolve the issue im having regarding the phase plots. First I will give you a little bit of a background on my setup and goals. Im currently trying to time align, and eq my JBL 4722 LCR two way active speakers. My ultimate goal is to use REW to take accurate frequency and phase measurements and export them to FIR designer and create an FIR Filter to linearize the phase and eq my LCR speaker drivers (HF and LF units) as well as tiime align them.
Current Setup:
Microphone - Umik2
Computer - MacBook Pro running MacOS Sequoia
Avr - Monolith HTP-1
DSP - QSC Core510i
50 foot Optical USB-C cable
3 foot HDMI cable
Currently I have the microphone directly connected to the MacBook via a long (50 foot) optical usb-c and that is connected to my HTP-1 via HDMI which goes to the QSC Core DSP and out to my amps/speakers. The MacBook picks up the umik2 right away and everything seems fine with that. I output audio using my HTP-1 over HDMI from my MacBook/REW
I get consistent frequency measurements, but I do not get consistent phase measurements when taking measurements of the respective HF or LF units; even when using the acoustic time reference option. After I take the measurement using an acoustic reference (my side surround speaker - not the driver im measuring for the LCR), I estimate the delay and unwrap the phase. The general shape is pretty consistent but it moves up and down on the phase plot vertically and I can't seem to get the same repeatable results which makes me unsure of what actual phase plot is accurate.
I am not sure what is causing this but some past posts have stated there may be issues with the fact that the UMIK2 has its own clock, and the Output sound card has its own clock; which could lead to inconsistencies. I do have a long run (40 feet) as my equipment rack is immovable and is well outside my theater. I am currently connecting the UMIK 2 to my MacBook with an optical Usb - C cable since it's a long distance. The HDMI connection from my MacBook to the HTP-1 processor is only a couple feet. I am lost on what if anything I could do to get more consistent phase measurements. I would appreciate any help in troubleshooting this.
Part 2:
I read in prior posts that a USB interface and XLR mic might be a better idea for more absolute timing references using an analog loopback.
I ordered a Motu ultra lite M5 and an earthworks M23R analog XLR mic.
I understand that I could create an analog loopback by plugging my mic into the first XLR mic input of the motu, then using a TRS cable from output 1 into XLR mic input 2 to effectively create the loop back timing reference. This is where things start to get a little muddy for me.
In REW I would be selecting Motu M5 as the output correct? So how would I get the appropriate channels ( Left, right, center, side left, side right, etc..) as if I was playing sound through the HTP1 when it was selected as the output? Would I be bypassing my HTP-1 altogether and trying to connect directly to my QSC Core 510i inputs (balanced euroblock connectors?) I guess I am a little confused how to implement this solution in my setup. If anyone can shed some light on that for me that would be great! Thank you!
Sincerely,
Raj
Part 1:
Current Setup:
Microphone - Umik2
DSP - QSC Core510i
3 foot HDMI cable
Part 2:
Sincerely,
Raj
