- Apr 3, 2017
- 9,638
I don't see any change of shape when adding an offset to the REF mic measurement. Remember to use "Add offset to data" after you move it.
All the measurements have abrupt high frequency cut offs, the REF cuts off at 10 kHz and the other two at 13 kHz. That's probably due to failing to capture the end of the sweep due to replay latency, use the acoustic timing reference to fix that.
