HDMI TEST BENCH: We Review AVPro Edge's 48Gbps AC-DA-12X2 1x2 HDMI 2.1 Distribution Amplifier!
Manufacturer & Model
AVPro Edge AC-DA-12X2 1x2 HDMI 2.1 Distribution Amplifier
MSRP
$300
Link
https://fave.co/4kIolY0
Highlights
HDMI 2.1 1x2 splitter with full 48 Gbps bandwidth, Supports up to 8K60 and 4K120 (4:4:4, 12-bit), Compatible with all major HDR formats including Dolby Vision, HDR10+, HLG, Built-in per-port downscaling (8K to 4K or 1080p), Audio extraction via TOSLINK and 5-pin balanced analog (7.1 multichannel and PCM), Full EDID control with 20 presets, 3 user-defined slots, Front panel LED menu with signal status and EDID/scaling options, Solid metal chassis with locking power connector, Supports HDMI 2.1b gaming features including VRR and QMS, Proven stable at full 48 Gbps throughput during 2.5-hour lab testing, Heat-tested chassis under load (91–96°F), Compact, install-friendly footprint
Summary
In this hands-on test, the AVPro Edge DA X2 proves it’s more than just a basic HDMI splitter. While many claim full 48 Gbps performance, most crumble under true max-bandwidth signals. Not this unit. It reliably passed a 4K120 12-bit 4:4:4 signal for hours without dropout, making it ideal for gamers, mixed-display setups, or any system that demands flawless HDMI 2.1 delivery. Add in advanced EDID management, per-port downscaling, and audio extraction, and you’ve got one of the most reliable tools available for modern signal distribution.
On this episode of HDMI TEST BENCH, we pace AVPro Edge's AC-DA-12X2 1x2 HDMI 2.1 Distribution Amplifier through a variety of tests. This device can evenly split an incoming HDMI signal between two HDMI outputs with variable resolutions up to 8K60. It's capable of handling HDMI 2.1b signals at 48 Gbps with 4:4:4, 4:2:2, and 4:2:0 chroma subsampling, as well as multichannel digital audio. Compliant with HDCP 2.3 and earlier, the unit also offers extended EDID management, including Custom EDID Blend support, which allows you to combine EDIDs from different devices, and can dump audio to an external source!
The question is: Does AVPro deliver on its claim of true 48 Gbps compliance? And does it supply a consistent, reliable connection? Watch the video review below and find out!
Buy the DA-12x2 1x2 Splitter from B&H: https://fave.co/4kIolY0
Buy the DA-14X2 1x4 Splitter from B&H: https://fave.co/44Z5fIC
AC-DA-12X2 1x2 HDMI 2.1 Distribution Amplifier Specifications:
  • Video Resolutions: Up to 8K 60Hz 4:4:4, 8K 30Hz 4:4:4, 4K 120Hz
  • HDR Formats/Resolutions: 420, 422, 444 (10-bit and 12-bit Deep Color)
  • HDR Support: HDR10, HDR10+, Dolby Vision, HLG
  • Color Space: YUV (Component), RGB (CSC: Rec. 601, Rec. 709, BT.2020, DCI, P3 D6500)
  • Chroma Subsampling: 4:4:4, 4:2:2, 4:2:0 supported
  • Deep Color: Up to 16-bit
  • Scaling (Output 2 & 4 only): 8K to 4K or 8K/4K to 1080p
  • Audio Formats Supported (HDMI): PCM 2.0 Ch, LPCM 5.1 & 7.1, Dolby Digital, DTS 5.1, Dolby Digital Plus, Dolby TrueHD, DTS-HD Master Audio, DTS:X, Dolby Atmos
  • Audio Formats Supported (TOSLINK): LPCM up to 5.1 at 96kHz/24-bit, Dolby Digital 5.1, DTS Hi-Res Audio
  • Audio Formats Supported (2CH Port): PCM 2-channel
  • HDMI In/Out Distance (4K60 4:4:4): Up to 50 feet (using Bullet Train HDMI cable)
  • HDMI In/Out Distance (AOC Cable, 4K60 4:4:4): Up to 130 feet (using Bullet Train AOC cable)
  • Bandwidth: 48 Gbps (FRL 6)
  • HDCP Support: HDCP 2.3 and earlier
  • HDMI Port Type: Type A
  • Digital Audio Out: Toslink
  • Analog Audio Out: 5-pin terminal block (balanced)
  • Firmware Update Port: USB-C
  • Operating Temperature: 23 to 125°F (-5 to 51°C)
  • Storage Temperature: -4 to 140°F (-20 to 60°C)
  • Humidity Range: 5–90% RH (non-condensing)
  • Power Consumption: 3 watts max
  • Power Supply Input: AC 100–240V ~ 50/60Hz
  • Power Supply Output: DC 12V 3A
  • Unit Dimensions (L x W x H): 76.2 x 75.44 x 304.8 mm / 3 x 2.97 x 12 inches
  • Packaged Dimensions (L x W x H): 150.88 x 76.2 x 20.6375 mm / 5.94 x 3 x 0.81 inches
  • Unit Weight: 0.68 lbs (0.31 kg)
  • Packaged Weight: 1.21 lbs (0.55 kg)
AV NIRVANA is member and reader supported. We may receive a small commission from affiliate links at no additional cost to you. We're providing the link out of convenience - if you prefer to shop with another retailer, we encourage you to do so!
