The all-in-one miniature shaker system is a great tool for the production screening of small components, engineering design evaluation and verification, or for educational demonstration purposes. It is also a great tool for on-site modal excitation and analysis. The shaker system features an embedded power amplifier, signal generator with open-loop control, and slip table for horizontal tests. The shaker itself has a frequency range of 1-15,000 Hz and maximum displacement of 0.75 inch, up to 500N, built-in power amplifier available for 20N shaker. It has an additional input port for controller with accurate closed-loop control technology.
New Mini Shaker System 500 N 112 lbf Vibration Modal Excitation Power Amplifier
Applications
Electronic Components Testing
Engineering Design Evaluation & Verification
Modal Testing and Analysis
Educational Demonstration
More Information about the equipment,
Shaker Model: LT-50-ST (Slip Table)
Power Amplifier Model: 750 W Air Cooled
Force Rating: 500 N Sine, 250 N Random, 1000 N Shock
Max Displacment: 20 mm
Frequency Range: 1 - 4,000 Hz Max
Mass of Armature: 1 kg
Sine Peak Acceleration: 50 g
Load Support Capacity: 11 lbs
Equipped With:
11.75" x 11.75" Slip Table
750 W Air Cooled Power Amplifier
Signal Input for Closed-Loop Control
Advantages:
All-in-one design with embedded power amplifier, signal generator, and slip table
Stand-along unit with great portability, and great demo tool for vibration related applications
Capable of signal input and accurate closed-loop control
Wide Frequency range from 1Hz to 15,000Hz
Series (VT-9002) Shaker Controller
UCON series (VT-9002) Shaker Controller is a cutting-edge vibration control product for electro-dynamic shakers.
Optional at Additional Cost: VT-9002 2-Channel Vibration Controller with Software for Sine, Random and Classical Shock Testing
Features:
Real-time close-loop control with 32-bit floating point DSP
Various models with 1-16 input channels available
Sine, Random, Classical Shock, and many other testing modules available
Wide sine control range from 0.01-200,000 Hz
Easy-to-use software interface and enhanced safety features
Asking Price: USD $21,650 Insured shipping
If you are interested kindly send me a message or mail
h7mhas@gmail.com
Thanks for looking..!!!
Applications
Equipped With:
Advantages:
Features:
h7mhas@gmail.com
