Frequency-linear txt export
Japio
Pascal
Hello,
I will first introduce myself: I am Jan Jaap Derksen from the netherlands. As hobby i am building professional audio speaker systems for bands or other events. (when covid 19 is gone....) I am using REW with the umik-1 mic till now just as indication of the frequency responce of the speaker and adapt the EQ manualy in the system.
i am struggeling with a problem in REW..The measurement of the speaker i can import into the DSP of my new amps to use FIR-eq. But the problem is this system can only handle linear line frequency responce.
When i am exporting a measurement as text file i cant find (or is not possibol) to export the frequency lines linear.
Accourding the dsp manual the file should like this:
FFT degree: 14
Sampling rate: 96 kHz
Samples in time domain: 16384
Lines in frequency domain: 8193 (0 Hz … 48kHz)
Line distance: 5,859375 Hz
File entries
Freq[Hz] Real[Pa] Imag[Pa]
0.000000E+00 0.000000E+00 -2.526122E-10
5.859375E+00 0.000000E+00 1.192093E-07
1.171875E+01 6.837189E-03 - 9.961390E-02
4.798828E+04 -1.115020E+00 -1.757477E+00
4.799414E+04 1.508967E+00 -2.896538E+00
4.800000E+04 -4.855079E+00 2.351044E-10…
35250
Is there a way to get this work? Or is it possibol due to update of the software to get this kind of exports?
Thanks in advance
Jan Jaap Derksen
Japio
Pascal
Which REW version are you using and what REW export options have you set?
5.20 Beta 60
I use export as tekst. I have played with the settings in the field popping up when you export as text. But it always the export is not lineart.
As you can see in the screenshot i have imported the file but checking the frequency it is not linear going up.
Or i am doing somthing very wrong. Till now no succes. I hope you have somthing about this information.
If your measurements are log spaced (they show "96 PPO" next to "resolution of measurement" in the export dialog) you should go to the Analysis preferences, de-select "Allow 96 PPO log spacing", then use the IR windows dialog to re-apply the windows. The export dialog "resolution of measurement" will then show something like "0.366 Hz" (depending on the measurement sample rate), export with "resolution of measurement" selected.
Japio
Pascal
thanks for the help. getting closer now. Only new problem showed up unfortunally. Just get a quick try with my laptop speaker and mic. no setup of real system.
do you got an idear about the sample numbers? i played already with custom range. suppose it is somthing like this.
35252
Japio
Pascal
after investigation looks like i am getting to many sample points at this moment. The file used as example has a line space of 5,859375 Hz. Now there is 0.366Hz. Is it possibol to modifi this by REW?
No, there isn't an option to alter the spacing. The application looks to be expecting a sample at 0 Hz and at Nyquist (24 kHz I'd guess) so you may need to add 5 entries from 0 Hz to 1.464844 Hz at the start of the file and make sure the last entry is at Nyquist. Total lines would then be 131073. You may be able to generate a subset in a spreadsheet, taking every 16th row to produce a set spaced at 5.86 Hz.
Please note that the file content is not real/imag, it is SPL [dB]/phase [degrees].
Japio
Pascal
thanks solved by adding at top and end the numbers manually. Now i have to figure out why the center impulse gives very high number. I get target out of latency in the DSP. I guess i need to ask the supplyer of the DSP about this.
