For sale: Yaesu FTDX-101MP HF/50MHz 200W Transceiver + Speaker/Power Supply + Accessories
h7m1
It includes a Yaesu FTDX-101MP transceiver, its FPS-101 speaker/power supply, factory accessories and manual
The Yaesu FTDX-101MP HF+50 MHz 200W transceivers' unique hybrid narrow-band SDR configuration achieves unsurpassed dual receiver performance.
The Direct Sampling SDR section provides astounding visual awareness of activity across the band as well as detail around the operating frequency on each receiver. The large, precision color touch-panel display also features gorgeous dual multi-function meters, dual frequency readouts and multi-functional touch controls, plus the exclusive 3DSS - Three Dimension Spectrum Stream waterfall and band scope.
The entire class-leading screen of the FTDX-101MP may be displayed on a user-supplied external digital monitor.
Ergonomically arranged transceiver controls are centered about a large, tactile and weighted VFO. The Main knob is enhanced with the MPVD; Multi-Purpose VFO Outer Dial which controls the sub receiver VFO, clarifier, VC-Tune RF Preselector, VFO fine tuning and a user defined Custom Selection function.
Each function of the identical Main (A) and Sub (B) receivers have separate independent front panel controls; AF and RF gain, Shift, Width, Notch, Contour, Digital Noise Reduction and APF.
Dual LED push-buttons comprise the Active Band Indicator for each receiver, enabling effortless and rapid independent band changes.
Adjustments of mode-specific settings and levels are displayed and accomplished quickly with the press-and-turn Multi-function selector. Every important control is strategically placed and readily available for maximum flexibility and ease of operation with this remarkable transceiver.
Features and Specifications:
World-Class 160 thru 6 Meters 200 Watt Transceiver for all modes; SSB, AM, FM, CW, RTTY and Digital
Superb and astonishing close-in dynamic range performance (120 dB RDR at 2 kHz spacing, 14 MHz, 500 Hz)
Hybrid SDR technology: Direct Sampling and NBW (narrow bandwidth) SDR
9 MHz IF roofing filters with excellent Shape Factor built-into MAIN and SUB receivers: 12 kHz, 3 kHz, 600 Hz plus 300 Hz in the MAIN**
High-Q VC-Tune Front-End RF Preselectors built-into MAIN and SUB receivers for maximum attenuation of -70 dB
400 MHz HRDDS (High Resolution Direct Digital Synthesizer)
Ultra-low phase noise 1st Local Oscillator
Completely independent dual receivers with general coverage receive
Yaesu's renowned interference reduction system with 32 bit IF DSP and digital noise reduction (DNR) and DSP Auto Notch (AN)
Inputs and Outputs:
SPS-101 Separate External Speaker and Power Supply combination is included, 95-264 Vac, 5A max., DC cable attached
USB B port rear panel; supports audio interface and transceiver CAT control
2 USB A ports on front panel support mouse and keyboard
RS-232 CAT interface (DB-9M)
SD Card slot, front panel
External Digital Display DVI-D Port, rear panel
2 External Speaker ports (A and B receivers)
2 Antenna Ports + 1 RX antenna (UHF female, SO-239)
2 Receive Out Ports (RX OUT A and RX OUT B)
2 IF Outputs (IF OUT A and IF OUT B)
UPC: 788026167616
FCC License Required to Transmit: Yes
Internal HF Antenna Tuner: Yes
Receive Range 1: 0.030-75.000 MHz
Receive System: Dual receiver
Dual Watch: Yes
Roofing Filter Capability: Yes
Third Order Intercept (IP3): Over 35 dBm
Transceiver Power Supply: External, included
Transceiver Input Voltage: 100-240 Vac
Transceiver Maximum Current: 9.0 A
Antenna Ports: 3
Dedicated Receive Antenna Input: Yes
Computer Connection Type: RS-232 or USB
Digital Mode Audio Input/Output: USB or 13-pin DIN
External Display Capability: Yes
Voice Synthesizer Capability: No
Hand Microphone Included:Yes
Radio Width: 16.535 in.
Radio Height: 5.118 in.
Radio Depth: 12.677 in.
Weight: 27.000 lbs.
Warranty: No
Quantity: One - Sold individually.
Notes: External Speaker and Power Supply combination included with transceiver purchase; dimensions WHD 6.299 x 5.118 x 12.677 in. Transceiver weight not including speaker-power supply unit. *Optional 300 Hz roofing filter for the SUB receiver and optional 1.2 kHz roofing filters for the MAIN and SUB are not included, cannot be upgraded by the user, and must be sent to Yaesu for installation.
Band Agility: Multi-band
SSB/CW Maximum Power: 200 W.
Price: USD$3,850
The equipment is Tested. Fully functional. Everything works as it should.
Contact me via mail with offers if you are interested,
h7mhas@gmail.com
Thanks for looking...!!!
