Export as wav - a problem
bobolix
Exporting the impulse response as *.wav provides a waveform, where the IR is adjusted so that the biggest peak has the delay set to exactly one second independently of any setting or entering of the delay, window or so. It means the information on the own delay of speaker(s) is completely lost. This would be a severe problem for me, as I need the impulse response also for postprocessing e.g. in MLSSA. Fortunately it can be overcame using the option "Apply IR Window before Export", but the length of the impulse response is not affected by the actual window length (i.e. from Left to Right) though.
Export lengths are zero padded if required to make sure they are binary powers, but the data is only the windowed part of the signal.
