Hi I have calculated in REW the filter for room equalisation. Now I would like to run a swipe in REW that takes account of the EQ correction in order to see (in the minimum phase zones) if there is a time improvement in the waterfall. I need to use an EQ, set manually in this EQ the parameter of the filters calculated in REW and then run REW. Which EQ could I use in OSX that works well with the REW parameters calculation and that works at OSX system level in order to be seen from REW? Thanks a lot. Alessandro
