Equalizer APO and measurements
Discussion in 'Official REW (Room EQ Wizard) Support Forum' started by z3d, Nov 30, 2018.
  1. z3d
    z3d New Member
    Jan 7, 2018
    0
    Hello there,
    I'm struggling to find a solution to the following problem.
    I'd like to be able to take measurements with REW of headphones and speakers which are EQed using Equalizer APO. The PC doing equalization and measurements is the same.
    The problem is that I can't do it.
    When using EQ APO with youtube, spotify, foobar it does work fine. When launching REW, it seems that EQ APO gets bypassed instead.
    I tried even using the program Virtual Audio Cable but with no luck.
    Do you have some tips about that?
    Many Thanks
  2. John Mulcahy
    John Mulcahy REW Author
    1,541
    284
    Probably a topic for the EqualizerAPO forum. EqualizerAPO only operates on WDM devices as far as I now, so you would need to use Java drivers in REW.
  3. z3d
    z3d New Member
    Jan 7, 2018
    0
    Thank you for your reply John, I will try to contact Jonas for some tips ;)
Share This Page
