Hi John.
I have some driver EQ settings intended for use in a DCX2496 that were provided to me by the designer of my speakers. The DCX2496 uses a proportional definition of Q, which you clearly describe in your REW EQ documentation:
Bandwidth = sqrt(gain)*centre frequency/Q
I've since moved past using an actual DCX2496 unit, and have for years been using a REW exported impulse response of the specified EQ convolved with my live music stream by my player. (Roon or HQ Player, depending on my mood.) The catch is that I'd really like to add low and high pass filters to my exported impulse response in addition to the parametric EQ, but the REW DCX2496 filter definition doesn't allow this even though the Behringer hardware itself supports it. (See section 4.3.3 of the manual. Note that I do not see high-shelf or low-shelf in the DCX manual, though you offer this in the REW DCX filter definition. Maybe this is just some label confusion?)
Even if the REW DCX definition adds the actual DCX LP and HP definitions, those are only good for either 6 dB/octave or 12 dB/octave, and I'd actually prefer more flexibility than that, at least 1 through 4 pole options. The only approach that I can think of at the moment is to generate a separate impulse response with the LP and HP definitions I want via the generic filter option, export it as a normalized impulse response WAV file, re-export my DCX2496 driver EQ impulse response as normalized WAV, and then find a 3rd party tool that can combine the 2 WAV files into a single new impulse response.
Is there some better way to accomplish this without leaving REW, especially as I don't currently have an IR merge tool on my Mac? Or could a modified DCX2496 EQ option be made that offers the LP and HP filters in a more flexible/extended (1st/2nd/3rd/4th order) form?
Thanks for any suggestions!
(Btw, apologies... I tried to provide a direct link to the DCX2496 manual, but the forum software viewed it as spam, so I unfortunately have to leave you to google it separately.)
