Hi All
First post here, I had a look around couldn't see a similar question. If this has been addressed just point me to the post, thanks
I have been using REW for many years but only recently looked at the EQ section. When matching the response to target, I get some useful corrections but the process is ignoring two major issues.
At around 41Hz and from 73 - 105Hz it is applying no filters. Is this because those issues are too far from the target level, or only areas above the target level get adjusted? Problem areas on either side get corrected. I have tried adjusting the Target and Filter Tasks settings, but those sections always get ignored.
Is there a way to get REW to add filters in these sections? Can you add filter points manually?
