Do I EQ for sweet spot or all seats
shueardm
Integra DHC9.9
2x Yamaha RX-V1
Panasonic UBD420
VAF DC-X
VAF DC-6
VAF DC-7
VAF DC-7
n/a
n/a
2 X SVS SB3000
Hi folks, newbie here.
My home theater has 2 seats, it's too narrow to make it seat more. However when I watch myself I move one seat out of the way and have my armchair in the middle,
So do I EQ to the sweet spot and ignore the other two listening positions? Given I am new and if i try making three spots flatter I'll probably spit the dummy in confusion?
I'll attach my 3 measurements, I don't even know if they are good or not. I have 2 SVS SB3000 which seems to boost the under 30Hz frequency by 6 db, the question is, is that good or should I try to make it flat?
Thanks for any input.
  • Average center.mdat
  • Average Left.mdat
  • Average Right.mdat
There is a fair amount of commonality between the measurements so you can likely find a compromise that will work reasonably for all three, failing that just using the centre looks like it shouldn't be detrimental to left and right.
