(March 17, 2026) Denon is calling it the “yes and” turntable. Meaning, yes, it delivers traditional analog playback. And yes, it brings Bluetooth into the mix. That framing gets to the heart of what the new DP-500BT is trying to accomplish, meeting vinyl listeners where they are today, not where they were a decade ago.
The idea makes total sense if you’ve been watching the market. Vinyl continues to grow, and not just among longtime collectors. New listeners are entering the space, often with expectations shaped by wireless convenience. Denon’s approach with the 500BT is to preserve the core vinyl experience while removing the shackles of cables and bulky separates that come with building a traditional system.
The DP-500BT sits far below the company’s DP-3000NE, but it borrows more than a little from that flagship design. You get a belt-drive platform paired with a static-balanced S-shaped tonearm and an aluminum die-cast platter, elements rooted in Denon’s higher-end engineering. The goal is mechanical stability and accuracy, creating a foundation that allows a record to sound full, controlled, and engaging.
Setup is intentionally straightforward. A pre-installed moving magnet cartridge comes ready to go, and the built-in phono preamp can be switched in or out depending on how the turntable is being used. That flexibility matters. It means the DP-500BT can drop into a traditional two-channel system, connect directly to powered speakers, or serve as a starting point for someone building their first vinyl rig.
Where things shift is on the wireless side. The DP-500BT supports Bluetooth streaming, including aptX, aptX HD, and aptX Adaptive, allowing records to be sent to compatible speakers, soundbars, or headphones without a cable. It’s a different way of thinking about vinyl playback. Instead of being tied to a single room and a fixed system, the turntable can follow the listener, whether that’s a quick session through headphones or music filling a living space.
For those already in the Denon ecosystem, there’s an added layer. Pairing with Denon Home speakers or HEOS-enabled components opens up multi-room playback, letting vinyl behave more like a streaming source. It’s a small shift in concept, but one that reflects the evolving nature of listening habits.
Operation lands somewhere between manual and automated. The DP-500BT is semi-automatic, with auto lift and playback stop designed to protect records while keeping the experience simple. It’s a nod to convenience without removing the tactile elements that define vinyl listening.
Physically, the look is clean and modern. A two-tone finish, low-profile form, and vibration-resistant construction give it a vibe that blends easily into contemporary spaces. Cast-metal feet add stability, and a removable dust cover helps preserve the finish and the hardware underneath.
Denon says the thinking behind this deck is rooted in how people are actually using music today. Vinyl sales continue to grow year over year, and buyers aren't averse to upgrading their gear every few years. That's where Bluetooth comes in, serving as a gateway that lowers the barrier for new listeners while offering an interesting new level of flexibility for more experienced users. That balance shows up in how the DP-500BT is positioned. It doesn’t try to replace a traditional high-end analog setup. Instead, it expands where and how vinyl can be enjoyed. You can drop it into a classic stereo chain, stream to a Bluetooth speaker in another room, or listen privately through headphones.
It’s the same record, just with more ways to hear it.
The Denon DP-500BT is available today, March 17, through Denon’s website and authorized retailers like Audio Advice (click here to order).
Related Reading:
AV NIRVANA may receive a small commission through affiliate links at no additional cost to you.
