BarrySchanz
Dayton Audio TS320D-4 12" Titanic Mk 4 Subwoofer 4 Ohm
$200 includes ground shipping to the lower 48 states
1.5 to 2.0 cubes ported is recommended
Dayton Audio's Titanic series subwoofers are world-renowned for their ability to create deep, hard-hitting bass with minimum distortion. This line of subwoofers has always been known for prodigious amounts of Xmax, relatively high sensitivity specifications, and an amazing ability to handle power.
Dayton Audio takes everything that has made the Titanic subwoofers stand out as top-of-the-line subwoofers in the loudspeaker industry and improves upon them in the Mk 4 generation. The TS320D-4 12" Titanic Mk 4 subwoofer has been redesigned from the ground up to improve upon every aspect possible, while maintaining the essence of the Dayton Audio Titanic series.
It All Starts with the Motor
The re-tooled motor focuses even more magnetic flux in the gap, for a lower Qes and Qts. This allows for higher fidelity performance in a similar sized enclosure as the Mk III 12" subwoofer, when more power is applied.
This American-made subwoofer has the muscle you need to pressurize your home or mobile audio system with deep, clear, clean bass. Check the structural integrity of your house, or car, before applying power!
And Everything that Made the Titanic Subwoofers Famous
Dayton Audio's TS320D-4 Titanic Mk 4 subwoofer is built with a sturdy aluminum die-cast frame to keep everything perfectly aligned while handling the insane amounts of air pressure it's capable of generating inside of a sealed enclosure. An extended pole piece keeps more of the voice coil in the gap for more motor control.
Frame openings under the spider help to reduce power compression (and trapped air) and the vented pole piece keeps the edgewound voice coil cool, for high power handling. The Kevlar-reinforced paper cone resists deformation under excursion, and the large rubber surround keeps cone travel linear. For a tight seal on the baffle, an integrated rubber gasket is pre-mounted to the frame.
Product Specifications
Nominal Diameter 12"
Power Handling (RMS) 500 Watts
Impedance 4 ohms
Frequency Response 24 to 500 Hz
Sensitivity 91.9 dB 2.83V/1m
Voice Coil Diameter 2.5"
Thiele-Small Parameters
Resonant Frequency (Fs) 36.3 Hz
DC Resistance (Re) 3 ohms
Voice Coil Inductance (Le) 3.5 mH
Mechanical Q (Qms) 5.28
Electromagnetic Q (Qes) 0.56
Total Q (Qts) 0.50
Compliance Equivalent Volume (Vas) 1.55 ft.³
Mechanical Compliance of Suspension (Cms) 0.13 mm/N
BL Product (BL)13.5 Tm
Diaphragm Mass Inc. Airload (Mms) 147g
Maximum Linear Excursion (Xmax) 19 mm
Surface Area of Cone (Sd) 498 cm²
Impedance 4 ohms
Total Q (Qts) 0.50
