Current Open Filename Display?
forumuser
I open and close a number of files during a REW session. It's difficult to keep track of current file especially if there is a big number of file movements. I tried to use the [File --> 9 history files] list but it also includes the imports so the most recent REW data file [.m] is not there anymore.
Is there a way to check this? If not, can you display current open file name on the title bar?
Alternatively this may be an option to turn On/Off under Preferences --> View?
John, many thanks for your excellent work and recent updates. Most appreciated.
Data from many mdat files can be loaded at once, so there isn't a "current" file name to display as such. The measurement panel shows the name of the file each measurement was loaded from, just below the measurement name.
