jtalden
- Marantz AV7705 Pre/Pro
- Main Amp
- VTV 6 chnl NC252MP P-amp x 2
- Additional Amp
- Behringer DCX2496 x 2
- DIY SEAS H1456/H1212 Spkr x 5
- DIY JBL 2235H 15" SW x 2
- Screen
- Da-Lite Da-Snap 39105V - 92"
- Video Display Device
- Canon Home Cinema LS11000
Thanks,Time using the left channel, chirp before and after. LFE 2 Xms means Sub 2 only at Xms delay total, LFE A means all subs played and repeated with timing 5,3,3
The 4 repeats of LFE A all are as expected for SPL delay and all other factors. The is no repeatability problem with your REW measurements.
The 6 delay timing changes to Sub 2 all show no impact of the delay changes. The Impulses are overlaid with each other instead of being offset by the delay differences,
Maybe the Acurus processor does not actually apply the new delay changes entered until another action is taken as exiting that page or exiting the setup mode completely or some other action is taken. If nothing else is found I would even try turning off the processor and returning the delay page to see if the new values are entered.
[The original SPL differences found with your shifted delay settings from (5,3,3 to 10,8,8 or whatever the shift was) could easily be explained if only 1 or 2 of the new SW delay settings were actually made.]
I suggest you investigate this.
