Credo Audio Switzerland "Cinema LTM" ...do tell!
Editor / Senior Partner
Baltimore/Washington Metro
Kaleidescape TERRA
OPPO UDP-203
Panasonic UB9000
Spotify
GoldenEar Invisa MPX
Quad Array SVS SB16s
JVC NZ8
Sony 65-inch A95L OLED
Sony 65-inch X900F
ZeroSurge 8R15W x 2
ZeroSurge 2R15W x 2
Anyone familiar with Credo Audio Switzerland? It's 3-way line source Cinema LTM speaker looks insane... would love to read some impressions if you've heard them in action!
51866
Here's some specs:
  • Three way floor-standing speakers
  • Line Array Enclosures: Sealed, Mid-woofer & Tweeter separated (optimized for low-compression)
  • Subwoofer: Sealed (optimized for low-compression)
  • Vibration-decoupled to the ground
  • Tweeter: 32 x 22 mm coated textile dome, neodymium magnet
  • Midwoofer: 14 x 4" fiber-glass cone (coated), neodymium magnet, low-loss suspension & drive
  • Subwoofer: 4 x 12 "aluminum cone, double ferrite magnet, 60 mm stroke
  • Crossover: Passive proprietary 3-way filters, coils: Mundorf CFC air-core, capacitors: Mundorf MCap Supreme EVO
  • Crossovers are mounted vibration-decoupled
  • Handmade by Credo Audio Switzerland
  • Tuning: Closed (optimized for low-compression)
  • Frequency response: 16 Hz - 20 kHz, +/- 2.5dB
  • Bass roll-off: 20 Hz @ 0dB / 15 Hz @ -2.5dB / 14 Hz @ -10dB
  • Efficiency: 85.5 dB @ 2.83V @ 1kHz @ 1m
  • Linear impedance: nominal 8 ohms, minimum 3.8 ohms at 10 kHz, max 9.1 ohms @ 200 Hz
  • Recommended amplifier power: For 95 dB at 1 m distance: 18 W
  • Recommended amplifier power: For 95 dB at 4 m distance: 100 - 300 W RMS
  • Weight: 155 kg (342 lb.) p.p. without packing
  • Size: (H x D x W): 187 cm x 70 cm x 27 cm (73.6 x 27.5 x 10.6") incl. isolation feet
