Hello! I've been using this wonderful piece of software for about 5 months, since 5.2.0 RC5. So far everything has been pretty good, I've encountered some minor glitches but nothing serious.
However, now I'm having problems with REW. Basically I've made an impedance measurement of a tweeter I had laying around and when I promped REW to calculate its parameters it returned me with the following error. I also own a Lenovo convertible laptop with REW on it and it gave me the same error during the same operation. I updated the REW version from 5.20 RC7 to RC13b (only on my PC, not on the laptop) and it returned the same error. I also updated Java from 1.8.9_261 to 1.8.0_301 but nothing. Regarding my laptop I'm not sure about which version of REW I am running but it's probably RC7 too. I am attaching the logs and the measurement files that I was trying to compute.
PC:
Laptop:
PC:
Code:
REW V5.20 running JRE 1.8.0_301 64-bit on Windows 10, it, IT, windows-1252 at 96 DPI
Message:
java.util.concurrent.ExecutionException: java.lang.NullPointerException
Stack Trace:
java.util.concurrent.FutureTask.report(Unknown Source)
java.util.concurrent.FutureTask.get(Unknown Source)
javax.swing.SwingWorker.get(Unknown Source)
roomeqwizard.eE$14.done(y:2198)
javax.swing.SwingWorker$5.run(Unknown Source)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
sun.swing.AccumulativeRunnable.run(Unknown Source)
javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
javax.swing.Timer.fireActionPerformed(Unknown Source)
javax.swing.Timer$DoPostEvent.run(Unknown Source)
java.awt.event.InvocationEvent.dispatch(Unknown Source)
java.awt.EventQueue.dispatchEventImpl(Unknown Source)
java.awt.EventQueue.access$500(Unknown Source)
java.awt.EventQueue$3.run(Unknown Source)
java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
java.awt.EventQueue.dispatchEvent(Unknown Source)
java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
java.awt.EventDispatchThread.pumpEvents(Unknown Source)
java.awt.EventDispatchThread.run(Unknown Source)
roomeqwizard.MeasData.phaseUnsmoothed(y:3622)
roomeqwizard.TSParams.initOptTarget(y:1020)
roomeqwizard.TSParams.lsqminAllParams(y:1602)
roomeqwizard.TSParams.optimiseParams(y:2479)
roomeqwizard.eE$14.B(y:1886)
roomeqwizard.eE$14.C(y:2832)
roomeqwizard.eE$14.doInBackground(y:3455)
javax.swing.SwingWorker$1.call(Unknown Source)
java.util.concurrent.FutureTask.run(Unknown Source)
javax.swing.SwingWorker.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
Laptop:
Code:
REW V5.20 running JRE 1.8.0_202 64-bit on Windows 10, it, IT, windows-1252 at 96 DPI
Message:
Stack Trace:
roomeqwizard.cE$14.done(y:368)
roomeqwizard.MeasData.phaseUnsmoothed(y:5467)
roomeqwizard.cE$14.B(y:1813)
roomeqwizard.cE$14.C(y:1021)
roomeqwizard.cE$14.doInBackground(y:1276)
