SimpleDude
- Aug 29, 2023
- 5
Hi All,
Have applied room treatments via acoustic panels and needed to do a new calibration with Dirac Live and post cal checks/corrections with REW, I had this issue last time (on 5.20.14) but never found a fix for it, running on Windows 10 connected via a DisplayPort > HDMI adapter going into the AVR for some reason I randomly get the "clock adjustment is too large" error, it happens most of the time and sometimes/rarely it doesn't, if it happens and I simply do the measurement again there is a chance it might not happen. This did not used to happen before on 5.20.13 and I think before a bunch of Windows updates, I did find a thread where John advised the user to download a newer "csjsound_amd64.dll" which I tried although I think that version of the file is already included in the newer 5.20.14 build ?, it didn't have any affect on the error, I would attach my MDAT file but am unable to post links.
Am I correct in believing when that errors happen it affects the impulse response so I can't check/verify the time alignment using the Impulse Response tab ?
Relevant info from my setup(I think) is:
All in all I've been learning this for the last year and a half or so, each time I come to do a calibration again there is a different/new issue I face be it with the room correction software of choice or REW which is very much putting me off doing this anymore.
- Windows 10 22H2 19045.3448
- RTX 3080
- Denon X3800H
- UMIK-1 connected via USB (have tried the cable it came with on both front and rear USB ports)
