Cheap Laptop Recommendation for REW/MiniDSP
newoski
Anthem AVM70
(1) Emotiva BasX A3
(2) Emotiva BasX A6
Triad Silver LCR
Triad Silver LCR
Triad Silver Sat/6
Triad Silver Sat/4
Triad Silver Sat/4
Triad Silver Sat/9
Triad Silver Sat/9
(2) GSG Hammer
I am looking to purchase a laptop for dedicated use with REW/MiniDSP. Can anyone recommend a cheap model from BestBuy that is definitely compatible? I’d love to stay in the $2-300 range and I don’t want to make the mistake of buying something that isn’t compatible.
dcibel
No Chromebook - “windows PC” all new computers will be “compatible”. But, you don’t get much for $2-$300 these days, I would buy a lightly used, check your local classifieds - FB market, Kijiji, Craigslist, etc.. also refurbished / recertified can be good deals. Without getting too specific on hardware, 8GB ram if you can for any general computer use today.
newoski
Anthem AVM70
(1) Emotiva BasX A3
(2) Emotiva BasX A6
Triad Silver LCR
Triad Silver LCR
Triad Silver Sat/6
Triad Silver Sat/4
Triad Silver Sat/4
Triad Silver Sat/9
Triad Silver Sat/9
(2) GSG Hammer
Intel or AMD better for REW?
dcibel
It doesn't matter. A potato can run REW. Search for best price/performance regardless of brand.
newoski
Anthem AVM70
(1) Emotiva BasX A3
(2) Emotiva BasX A6
Triad Silver LCR
Triad Silver LCR
Triad Silver Sat/6
Triad Silver Sat/4
Triad Silver Sat/4
Triad Silver Sat/9
Triad Silver Sat/9
(2) GSG Hammer
Sweet. (For context, I have a dual 2080 TI gaming rig I built from scratch. I’m just paranoid about Java / AISO not behaving etc)
sam_adams
If you are concerned about using ASIO and a JRE on Windows, buy a Mac. The window is closing on used 2012 MacBook Pros (A1278) over on ebay. They can be had for $200 or less with enough resources to run REW as soon as you receive it. Don't like Macs? REW runs on a Chromebook just fine. $300 - $400 gets you a Chromebook with a 1920 x 1080, 15 - 17 inch display.
For our miniDSP workshop we use the small student version ASUS laptops. The only catch is you have to convert them to Windows 10/11 which is a free download in the MS store. We just pick them up at Best Buy.
Deer Creek Audio is an authorized miniDSP dealer
rvsixer
Just googled it quickly...looks like Chromebooks capable of running Linux emulation will work (or dual boot install, etc.). Ready for another learning curve?
I'd just get a cheap new/used pentium/celeron x86 notebook, if its got windows great, if not throw a Linux distro on it with native linux REW.
And may as well make it fanless, so you don't have a fan blasting your measurements. There's several in the $300'ish price range Acer Swift1, Asus Vivobook, HP Laptop 14, etc. (google fanless laptop). Just be aware if it comes with Windows in S mode, you may have to upgrade to full windows at some point.
skid00
2 x Adcom GFA 555
I'm using a Microsoft Surface Go 2. It has a USB 3, and a USB 2 connector, so I can output to my DAC, and plug my Umic in at the same time. I run eqAPO using the REW EQ output.
Privatier
SPICA
Get the highest screen resolution you can afford. REW smallest window size is 1024x720. A higher screen resolution allows for seeing something else at the same time, for example for notes or folder contents. Otherwise you need to switch forth and back.
rvsixer
Where can we get one for the OP $200-300 price range ? I'd buy one for that price.
BJB
I would suggest to get one with an HDMI port not displayport so you don't need to convert to hdmi and can run natively. Less variables to debug. I use an older laptop I added memory to for this reason.
BJB
